smokey
Be3 Gearbox Bolts
smokey
Hiya guys
I was wondering if you could help me?
I'm struggling to find the part number for the bolts to fix the gearbox to the engine.
I recently bought these 6923 81 as this was the only part i could find on service box.
But these only fitted on 3 of the places. I seem to need a bolt with a nut on the end and a smaller bolt.
Also do these bolts screw in the starter motor as well?
smithy
Hiya guys
the gearbox bolts you have are probably the top 2 and the front one,the one round the back by driveshaft i think is a shouldered 10mm with 13mm head if memory serves me correctly.can you not just go to a local supplier to get one?
the starter motor bolts are 10mm with 8mm allen key head one is slightly longer than the others.
6923 81 SELF-TAP SCREWS M10 X 1.50 - 75
these fit in 3 of the 4 locations, the 4th being an allen key head from the block side, it has a square washer.
6913 K3 SCREW DIAM 10X1.50-70
2221 26 STOP PLATE 17 X 17
I think these are the starter motor bolts;
6913 D0 SOCKET SCREW DIAM 10X150-60
6913 56 SOCKET SCREW 10X150-65
These are the same as any XU>BE engine, so 306's, 406's to name a few so any scrappy will have them
smokey
Thanks guys
I managed to get the allen key bolt and the starter motor bolts from a 205 diesel at a breakers.
I decided on taking the starter motor too as it was a long slim one (but still a Mitsubishi one) This came off a 1.9 205 Diesel. This morning i checked the number of teeth and my old fat starter motor had 9 teeth and the new slimmer diesel one i got yesterday has 10. So surely this wont work on my Mi16 engine? Or will it still crank with the extra tooth?
