joe1joe
Having bit of a problem with my vss on my Gti-6.
I have got a sensor with the cable and sensor drive
But the gear on the end of the sensor does not mesh with the plastic
Gear in the box (has about a 2mm gap)
So are there different size vss drives? Or the peice you can pull out the
end Of the vss? As thought they were all the same size!
Edited by joe1joe
GTI6BOY
You should have a red gear on your sensor and a cream gear in the box, if either of these are black you need to use both black or red and cream
joe1joe
Ok, well I have got a brown and cream sensor end, and they both seem to be the same size but I have the black gear in the box though, so on a parts list will it state the colour?
GTI6BOY
Gti6 use black and black
205 use red and cream
brown and cream wont work with the black gear
