stu8v
Whats The Requirements To Hit 180-190bhp (mi16)
All Praise The GTI
how easy is it to do on a 6 while engine is fitted welshpug?
  All Praise The GTI said:
150lbft
How many kW or hp at the wheels?
All Praise The GTI
not sure what it is atw
these are the specs you sent me peter :(
Specs.
Std. GTi6 inlet
duration 205 deg. @ 0.050" lift
Lift 0.394"
Stage I GTi6 inlet
duration 215 deg. @ 0.050" lift
Lift 0.380"
I'd be installing the cam in the standard position first, using the dowel pins to lock the pulleys & crank. If you want a bit more low end try advancing 2 degrees.
Edited by All Praise The GTI
James_m
That's the thing with N/A tuning, its a bit hit and miss. It would seem no 2 engines are ever the same!
Not at all, I know my mear std 8v 1.9 in the CTi made about 132 bhp on a RR day and even the operator was surprized compared with the other cars, Mind I had fully advance on the Dizzy and it pinked low down, But hey it was a nice figure to get
wracing
all praise the gti, you know why your not making the power, the mapping was an utter bollocks job. I hope you have managed to get it back to emerald from when I last saw it. It sounded like the bodies are out of balance I may be wrong. personally I would leave the cam timing standard and get the fuelling and ignition sorted.
James
All Praise The GTI
hi james, well after dave turned the throttle screw the wrong way and put them more out of balance and then mapped it the first time :(
i fugured out what he had done and sorted them althou he didnt bother checking they were balanced when i went back on friday :huh:
he adjusted the idle settings so it wasnt running stupidly rich but thats all he did. wouldnt even check the map just said it looked fine or try tweaking it for me or do another power run.
not too happy considering how much cash he had off me for a couple hours work...
i think abit more power could be found by sorting the cam timing but no idea how to get that done or who i could trust to do it??
