TeCh2pe
Mi16 Ignition Distributor Bracket
TeCh2pe
Hi!
I have a problem getting hold of a ignition distributor bracket for my Mi16 DFW engine.
My local Peugeot dealer here in Norway told me it is out of production.
It is the part no. 2/02 seen in this picture.
Maybe someone in here got one or two for sale?
Thank you in advance for reply! :)
TeCh2pe
Anyone? ;)
JRL
I got one new a couple of years ago they go discoloured very easy and when they are new they look bright white Im trying to remember where i got it. Go to the wanted section on this forum and request this part someone may have one.
all the best
TeCh2pe
Thanks mate! I'll give it a try ;)
Are you sure it's that bit? Looks from the picture that it's actually the part that is bolted to the end of the cam that the rotor arm screws into, rather than the white plastic part that goes between the dizzy cap and the head.
TeCh2pe
Thanks Anthony! I took a closer look and you're right!
It' is the white plastic part that goes between the dizzy cap and the head. My bad! :unsure:
Actually I need BOTH parts when I think of it.
Cant post in the Wanted section. Dont know why...
Maybe someone can link this post there?
Cheers!
DrSarty
I have both parts. £25 posted.
You don't have enough posts for a wanted ad (30 needed).
Veero on here used to be able to get brand new white plastic base rings.
TeCh2pe
Sold! Nice knowing! Sent you a message! :unsure:
