katmav
Ecu Repair
katmav
Pin 18 on my ECU has completely Corroded away. Has anyone ever replaced one of these themselves? This is stopping power going to the Fuel Pump through the associated Green Relay.
Pins 11, 12 & 13 are all unused, can I use one of these as a replacement or will it brake a circuit on the PCB?
smithy
Personally I would not bother trying,best to get a replacement ecu if you have standard set up.
I bought a 1.9 one and sold a 1.6 on the fleabay for about a tenner so not worth trying to repair it in my opinion
GLPoomobile
I've got ask the question - any idea how on earth you have a corrdoed pin on the ECU? :unsure:
if its from a 405 then its fairly common, as the ecu is sat in the scuttle panel, any blockage and the ecu gets submerged.
I've also seen it before on a 405 ECU.
I don't know whether you'll be able to use another pin, you'll have to open the box up and investigate yourself.
If its a 3 row then Simtek do sell the socket for £11.40 + vat http://www.simtekuk.co.uk/www.simtekuk.co....ch=&sought=
they do offer a small discount to 205gtidrivers members.
Edited by welshpug
katmav
Not a clue!!! Its mounted inside the car and some how its all damp inside the connector, all other pins are fine just the one disintegrated along with its spade connector. Very odd.
Anyone got a spare ECU for sale then? :P
Flying205Nutter
Which ECU do you need?
katmav
Need an MI16 3 row - Bosch 0 261 200 355
Flying205Nutter
Sorry I only have a 2 row.
Tedglenn
sorry guys maybe a stupid question...where is teh ecu on a 205 ? I want to disconnect it before welding. The car is on stands and i don't wnat to roll around insdie it without a clue as to its whereabouts.
Thanks Ian.
Ryan
It's under the dash just above the drivers right knee. If you take off the lower panel that goes under the steering column then you'll be able to see it.
Tedglenn
