bearmach 0 Posted September 15, 2010 Hi does anyone have a picture of the layout of 205 gti 1.6 brake line`s Share this post Link to post Share on other sites
Daxed 7 Posted September 17, 2010 What are you looking for? Front m/c layout? How the pipes fit with the beam? Position of compensator? etc From memory the Haynes manual has diagrams of the pipe runs. Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted September 18, 2010 The brake lines on a 1.6 GTI (any year without ABS) run both front lines from the end of the m/c & the rear from the single outlet on the m/c across the engine bay to the compensator behind the battery tray on the inner chassis leg wall. From the compensator it runs underneath the car to the T piece above the rear beam where it splits across to the right running to the rear flexi around the beam & rigid along the radius arm to the wheel cylinder or straight to the flexi into the T piece for the left rear drum inthe same way. 1.9 GTI has front rear diagnonal split from a different four port m/c of the same internal bore (20.6mm). Graham. Share this post Link to post Share on other sites
