JRL
Mi16 Sump Baffle
JRL
After quite some time seeing my oil pressure reading drop when I cornered hard finally got me round to fitting a Constella baffled sump and uprated pressure spring. It certainly has helped I dont drive it that hard but I no longer get the surge as I used to so im a little less worrried now. Definitely worth doing and pretty easy to.
smokey
How much was it mate?
My Mi has just the standard sump at the moment. Engine is about to be put in. I was going to see how it did as mine will be only used on the roads.
But it is in the back of my mind of something to do. Whether i do it now or at a later time i just dont know!!
JRL
you could alway see how it goes then just put one in next oil change. All you need is two new sump gaskets undo the sump bolts bang it in and job done.
backroadpug
Sump gaskets? i always thought they were just on with sealant
Sealant will be fine too.
It's basically a copy of the PTS jobby.
JRL
I bought two gaskets ready for fitting but when I took it to put it on the ramps i had left them behind at home so just used sealant anyway. Has not leaked yet.
