TT205
Glue For Gear Knob Top Bit
TT205
On my phase 1 the top of the gear knob has come off, there is a little foam underneath which feels rather perished - is it best to use an impact adhesive or something different. I presume superglue would dissolve the foam?
Dave
JRL
Foam? just shove some glue in there youy may not even need super glue, and im sure it will be fine.
TT205
TT205
Still haven't done this yet
Which do you reckon would be best - impact adhesive or epoxy
JRL
If you used silicone it wil bond but can be removed if you ever need to replace it. Personally id go to halfords and look at the glues they have lots of types pretty much any will do. I think I used this evo-stik before when securing a rear reflective panel its still on now and thats exterior.
http://www.halfords.com/webapp/wcs/stores/...tegoryId_165691
Stevo309
I would avoid solvents and use an impact adhesive like eve stick. A silicon based glue would also work ok like the cooer glue from a glue gun.
The foam will have been the double sided sticky pad things that you used to get with mirror tiles etc but silicone sealant will do fine imo.
Clean all traces of the foam off & a blob of sealant instead, just like on the rear badges.
Graham.
MerlinGTI
I'd use a 2 part urathane (sp?) like upol 915. Silicone/evo stick etc.. Would do the trick tho I would of thought :lol:
TT205
Cheers guys - will get it sorted
