nick
Gti-6 Arb End Plates..
nick
Quick question, are 306 gti-6 end plates the same as 205 ones? I'm fitting a cut down 306 bar in the 205 and just wondered if i needed the 306 end plates as well??
Edit - I mean are the splines the same on each bar....?
Thanks,
Nick
Edited by nick
jord294
Thanks,
Nick
no they're not the same. there are larger splined ends on 306 arbs
AdamP
You'll need the 306 end plates AND the rubber bushes.
If I were doing it again I'd use the 306 end plates on a 106 GTI ARB which is a straight fit, however the cut down 306 bar has caused no problems.
nick
Thanks lads, wanted add coming soon......!!
Nick
