peter
306 Hub, 205 1.9 Hub
peter
Iv been looking into fitting these hubs to my 205 instead of fitting the 1.9 gti hubs, as they are getting more expencive and hard to find!
Ive read somewhere that they will give positive camber? So im assuming the position of the ball joint hole/clamp is different to a 205 hub.
Ive had a search but can't find any dimentions.
Has anyone done it and sorted out the positive camber?
They look similar but the 306 do give noticable positive camber. Not good if you like your car to handle!
later ones have a hollow cast construction, and an 18mm balljoint, same applies as above to these.
the position of the balljoint is the same, but the angle of the damper body clamp would be different.
