boombang
266mm 306 Xsi Brakes - Flexi And Discs On 1.9 Hubs
boombang
Just checking that the connection in roughly the same place for flexis so can use 1.9 hoses?
Also what discs would you use with the 1.9 hubs?
I've certainly fitted them before using standard 1.9 hoses, and you need the same 266mm disks as fitted to the 306 XSI/S16/HDi :rolleyes:
boombang
Ideal info thanks for quick reply Ant. Even cheaper for me then!
Uses the same bolts as the 306 too, or assuming you had 1.9 calipers on there previously, they'll fit too :rolleyes:
allanallen
There's 2 different types of discs for 266 brakes the early ones are 20mm thick and the later are 22mm with a different offset.
The later calipers defenitely fit with standard hoses as I'm running a set, al
boombang
At the moment have 4 pots, sure I have some 1.9 caliper bolts somewhere - maybe even they will come with the calipers.
If anyone is wondering why I'd go from 4 pots down to xsi calipers, is due to the stack of 14" A048s I have in the garage, plus a set of almost new A539s for hacking about in.
4 pots will be up for sale very shortly!
pip470
I was about to ask if this set up would fit under the 14 " wheel. Thanks
