yeti-dj
Can You Change The Trip Odometer In The Clocks?
yeti-dj
hello, before i go and buy some more dash clocks to rip apart and find i cant replace the odometer trip i thought i would ask the question.
so is it possible to replace just this part, dont want to replace the whole clocks as i have the ones with the numerical markings around the temperature gauges?
thanks for any help.
Henry Yorke
the clocks are in sections. So you can change the centre dial as one piece and keep the surrounds with the numbers on and retain your original mileage. I did this with a set of my clocks. However I did find that it was over reading the MPH with one and when I put another set of clocks in it read the right MPH so there is some difference between speedos. Exactly what I do not know!
yeti-dj
cheers for that, i will get the clocks out in the morning and see if i can sort them.
thanks.
