vickiw106
Crank Sensor Wiring
vickiw106
thanks for looking
i am currently in the process for making my wiring loom for a stand alone ecu
i need to fnd out wht the pin out put is from the crank sensor
i am running this type of sensor
i am looking to find out which one is the screen pin the v+ and the v-
sorry if this is in the wrong section
thanks
ian
What car is the crank sensor from?
AFAIk they are all the same pin out on any ecu which on the mm8p loom I'm boxing up for baz the shielded wire goes to pin 3 on the plug for the cas.
Graham.
Mad Professor
That looks very much like this one:
0656-14-43-13
Pin 1: Signal (+).
Pin 2: Signal (-).
Pin 3: Sheild.
