dino20vt
Rear Beam Part Thread Size?
dino20vt
I removed one of these today:
And partially knackered the thread.
Does anyone a) know what size tap I'd need to clean the thread up, ;) where I'd get one from in Leicester or c) get it done in Leicester?
I'd try to clean it with a thread file, without measuring one I don't know the thread size, but I'll bet it is an oddball fine metric thread, and a tap will be hard to get hold of, and expensive.
dino20vt
Sorry should of worded it a bit better, I mean the threads on the beam casting are knackered.
Looks like buying one is out of the question then, can anyone think of any engineering shops in Leicester or Northampton?
Edited by dino20vt
Ryan
It's 30x1 iirc, which is a very odd size, and a tap won't be cheap.
dino20vt
Won't be buying one then!
EdCherry
Probably mean 3x1, 30 is a bit bigger.
More likely to be 30x1 given the size of the plug Edwardo....
EdCherry
Looks pretty small to me comparing it to that finger nail, but hey never messed around with beams.
dino20vt
I agree it does look pretty small and I've got small hands so what's all that about? Makes my knob look bigger though!
Here's a better picture: (not of my knob)
Edited by dino20vt
Alastairh
Does that mean you've got the bar out then mate? I hope you haven't put my trusty sledge to shame! :)
EdCherry
Nah im probably just being retarded its probably 30x1
dino20vt
It does indeed mate. I took it to my mates garage and pressed it out, only took 300 psi (is that much?) to budge it and it didn't even bang, unlike the other side still attached to the arm and the shaft in the arm which scared the sh1t out of me when it went. So I'm guessing the trusty sledge started it off! Don't suppose you've got the disc backing plates have you mate as I can't find them anywhere?
marksorrento205
I have a tap this size just for this job. I know its a treck but if you got stuck and wanted to pop over and use it feel free :)
swordfish210
Anyone know the part number for these, i fancy getting some new ones for my beam.
Ryan
5154 05 - about £4 each now :rolleyes:
Mark, I have some new ones, yours for 5 quid a pair posted, I've only ever needed to change the odd one.
swordfish210
Legend. Pm'd :rolleyes:
