jonathan205 0 Posted August 25, 2010 Can anyone post a picture for me that shows the standard front wheel camber on a 205gti? Mine seems almost positive and the edge of the tires are wearing downquickly :S Share this post Link to post Share on other sites
Anthony 1,002 Posted August 25, 2010 As standard, they run pretty much zero camber on the front, and can subjectively look to be positive - especially at standard ride height. If both sides look the same, there's probably nothing amiss. I tend to find that it's quite easy to wear the edges of the tyres prematurely on this setup when driving in a "spirited" manner, but it's much worse if your tracking is out - get this checked, and in my opinion, run less toe in that the Peugeot specifications recommend (even going to zero toe) as this will only worsen the wear on the outer edges Share this post Link to post Share on other sites
Jamal 2 Posted August 28, 2010 Hope it helps. The upper is the 306 ABS hub, de lower is the std 205 GTi hub. Share this post Link to post Share on other sites
