weejimmy
Is A Xantia Hdi Box Same As A 306 Hdi?
weejimmy
was looking for a 306 hdi gearbox but have seen a xantia hdi (90bhp) box for sale
are these the same ratios or similar?
anyone know ?
cheers
edit: or a partner van hdi box , theres one of them also.
are they shorter/longer than 306?
Edited by weejimmy
I believe that Xantia HDi 'boxes use a hydraulic clutch setup and are ML5, rather than the conventional cable setup and BE3 box used on a 306.
weejimmy
this one is cable definatly,
its for a 205 , not that that makes a difrence
S@m
According to citroen servicebox the Xantia HDI could have either an ML5 or a BE3R depends on RPO number of the car.
weejimmy
thanls for the help folks i got it, it looks exactly the same so should at least bolt up fine.
S@m
The easiest way to tell if its a BE or an ML in the Xantia is that all the ML gearboxes had cable gearchange whereas the BE's have gear rod/linkage like a 205.
Sam
