carlh.1
Which Coolant Pipes To Use For Turbo?
carlh.1
Could someone with a 8v turbo tell me which coolant pipes to use as feed and return on the turbo housing, at the minute the top heater matrix hose feeds then returns to the distribution block at the bottom of the engine. Is this wrong? any help would be brilliant
Depends on which engine first
samc
on my turbo'd 1.9 i used the pipe that comes from the thermostat outlet to the header tank, just run it from thermostat - turbo inlet - turbo outlet - header
carlh.1
Thanks. I thought it could have been piped wrong as it is the turbo will be heating the matrix pipe before the thermostats opening. thanks again.
