Guest hixsy
Temp Sensor
Guest hixsy
evening guys, cant find anything on the search area so would any1 know where to get a coolant temp sensor from please? GSF failed.... i have a H reg 205 1.9 GTi.
thankin you in advance
gsf, but under a BMW part number.
Assuming you mean the ECU coolant temp sensor, as said, GSF do it.
They've changed their part numbering scheme recently, but the old part number is B93490 which hopefully they can cross-reference against :)
Guest hixsy
The bit that screws into the engine block is wat I'm after, I will call them today and see wat they say ...
