custard-rallye
Worth Changing To A Gti Subframe From A Tu One?
custard-rallye
as title says is it worth changing or better off spending money elsewhere??
blessed6383
wouldn't of thought there was anything to gain plus the gear linkage mount is in a different position so might not be able to use it unless changing gear rods
custard-rallye
uncle is a welder so thats not a prob i just thought getting wishbones would be better than the tca's
BERTMAN
definently not, GTi setup up is much better imo.
custard-rallye
Thought it would be better what do I need to fit it is it a straight swap bar one mount
SebRad
Hi, you will need the subframe and wishbones (obviously). You will also want the anti-roll bar and mounting bushes / brackets. The anti-roll bar connects to the struts with "drop links" so may well want GTI struts in order to have to mount points already on them.
I believe you may also need a little work with the brake pipes so they don't rub on anything, the GTI has them routed slightly differently with the bracket on the car at a different angle.
Dug out a photo of GTI vs non-GTI suspension for you:
Regards, Seb
BERTMAN
i read the question slightly wrong!! sorry. You'll need;
GTi subframe, and relocate the gear linkage
wishbones
GTi arb
droplinks
and GTi shocks
i drove around without the shocks for a little while, and therefore without the arb attached and it was awful!!
Edited by BERTMAN
