Flozman
[engine_work] Lean Mean And 1990 Sorrento Green.
Flozman
update, as things are rolling to the end of the extended bank holiday I feel it may be the time to show my face. NOTHING has gone to plan, im all out of love and things are just starting to get serious.
I did this in the carpark outside.
Flozman
Okay so im using;
Baker BM (another free plug) Top mount and gearbox bushes,
New xantia bottom bush (same as all XU really)
Baker BM Thermostate adapter
I havent decided on what kind of water distrubution block to go for, ive kind of just decided i have enough hoses to cover all matter of experiments.
I think something that dosent get covered a lot maybe the close proximity of the exhaust to the fuel lines, but on the other hand it might be so blatent nobody feels it needs a mention.
However for the sake of the guy who finds this in 2015 via the search function (having begun in 2006) if you replace the fuel hoses from the bulkhead while the engine is OUT this can save you a lot of time as you really
need to extend the lines to get them to run away from the heat source and rather than relocating the fuel filter replace it with a simple inline item or a smaller Xantia one like i bought today.
The Brake Master cylinder gave me no hassle i found the cambelt cover only restriced the fitting but had a lot of give, I took a small metal file to the edge of the rocker cover until i had the clearance to fit the M.C. and a little more for good measure then when I fitted the coilpack cover I had a good template for the cut line though the plastic.
Flozman
Clearance on this manifold is better than i expected.
Flozman
My big problem at the moment is the fecking power steering, I used the standard Xantia engine mount bracket which i thought was going fine until the point i relised the Xantia pump has a high output for the suspension which cant just be blocked off. So I made my way to the breaker and found a pump from a 406, which looked about right. But when i got home the bottom holes dont line up and the pulley wheel will foul. Worst bit is the xantia fitted perfectly but just had to many outputs. So im thinking about another bracket or just buy a manual steering rack. Any rate ive bought a pump i have no use for and Im back to square one.
If anyone is interested, ive used the 1.6 Be3 gearbox, flywheel (about half the size) and new 1.6 clutch kit.
feb
Thanks for the head up, I will be cleaning or replacing all the contaminated parts. If I can be perfectly honest I dont have a clue what the phase my car is or what parts should go, I'm more at home on German and Italian vehicle's.
What is the purpose of the metal gubbins in the oil filler cap?
Is it just to hold potential mayonaise?
What if they are removed completely?
http://img.auctiva.com/imgdata/1/1/1/6/1/5/7/webimg/301931497_o.jpg
Flozman
I dont have that in my cap, but if you imagine the gunk you have collected in the oil return pipes this could save any large chunks falling back into the oil so keep it and give it a rinse with petrol every service time.
Flozman
XANTIA XUJ4R MP5.2
XUJ4R 205
CC2B Switched Live 46B
BB8 Perm Live
B14A Perm Live
122B INTERIA BH12
122A INTERIA BH12
8055 AIR CON
1360 VSS
1234 AIR CON
1232 PURGE
822 IMOB
821 IMOB
820 IMOB
426 REV COUNTER 112B
142 DUNNO
141 DIAG SOCKET
140 DIAG SOCKET
123 LAMBDA BH12
120 FUEL PUMP 76
KEY BH12 FUSE BOX
401 47A COOLANT GAUGE
410 30 OIL PRESSURE LIGHT
411 30A OIL TEMP
C120 52 REV LIGHT
220 53 REV LIGHT
1070 7A ALTERNATOR LIGHT
400 47 COOLANT LIGHT
414 30B OIL PRESSURE
Flozman
Two weeks and still no thermostate adapter or engine mounts...Gay
Flozman
While the sorrento is waiting for its downpipe, thought i might share deisel slag. Some of the parts replaced are Fuel solinoid, downpipe gasket, resonance chamber, control arm, track rod ends, two starter motors. The paint has gone on every panel, the ariel is broken, the vin numbers and tag have been removed at some stage in its life and Im reaching the new milestone of 225,000 miles in all likleyhood without the aid of a service. Ive set myself a challenge of seeing if It can make 250k before the next MOT in Novemeber.
I was even brave enough to take a 400mile round trip to rainey Wales about a month ago, fully laden making resonable speed.
Flozman
Suppose id better update considering its been a while and ive done stuff.
Anthony Kindly offered to swap my PAS rack for a Non, which basically came down to removing the subframe and gubbins in about the worst downpour in history. Anthony kindly helped whilst I scrambled around for tools (before I got a garage).
Next day i was out cleaning the new rack and subframe before reinstallation.
Flozman
I was rather pleased to recieve my re-angled manifold and my adapter from Stew, but the build was starting to get put on hold. Call it what you want but if you dont have the money to buy what you need everything starts feeling like a struggle. I didnt want to take everything apart again in a few months and the car was pratically worthless.
I managed to salvage some parts off the Diesel, so amongst other things i can bin those horrid phase one mirrors. Anyway after a few months on the axel stands I'm making a comeback.
Flozman
Thanks to all who have sold me parts, like the chap who sold me those Koni's for £30!!!
Flozman
Any after enough faffing about and lots of piss taking, i decided id give the engine a kick in the arse. I've never been that concerned with huge power output, its such a pointless task trying to compete with people who have more money or are just better mechanics.
But I like working the underdog card so if you spotted it thats a RS loom and ECU +
Flozman
More toys from Stew
Trying to get to grips with the new loom
Flozman
So far i've replaced all the bushes and nyloc nuts and bolts. The discs are 266mm but i had a play with a 406 setup and regardless of the fact they didnt fit very well, they are just too heavy.
allye
I herd you got some tasty belts too :ph34r: Looking good though, never realised this one was yours!
Flozman
Flozman
Haha caught me updating my thread, I cant wait to fit them!
Matter of fact I just cant wait to start tarting the car up it aint had a coat of wax in 8 years!
Flozman
Bosch calipers tidied up with some coach paint.
Air filter needs extending to clear the top hose.
My custom made coilpack retainers
First startup without exhaust!
Flozman
camgti
Nice job. Great work with the 16 and the car looks great!
If you can manage, you should try and refit the battery and move the filter further away from the throttle body. Will give you a better sound and give it a longer inlet tract length leading to possible torque gains etc. It worked on mine when I changed it anyway
Cam
don't bin the mirrors! i'll take them for a friend :)
