Vz_ace
406 Coupe Brembos
Vz_ace
Would these cylinders and 288 xantia discs fit under Speedlines sl434 without using wheel-spacers? I have got 205 1.9 hubs.
Has anybody allready tried this?
cheers,
V.Zaloznik
ben25
cheers,
V.Zaloznik
12mm spacers minimun for sl434 on 306hub so I hope it's the same for 205.
It's an urban legend that brembo fits under speedlines without sapcers...
Daz_C
I've got brembo's behind mine but have had to use spacers. I had some decent hubcentric ones made by my mate. Not had any issues with them.
Richy_cti
get the 406 coupe starfish alloys 16" they only just fit under but still pug wheels and think they would ok on a 205
Vz_ace
@daz c: What is the thickness of your spacers?
cheers,
vlado
Speedline 1508 will fit over them, as will Team Dynamics Pro race 1.2.
Daz_C
cheers,
vlado
I think without checking 16mm.
I also have some speedline 5 spoke thingy's which fit over brembo's without requiring spacers.
Vz_ace
So, you have got Sl434's and 16mm spacers. What tyres do you have on them? Do the tyres stick out of the arches (wings) anywhere?
cheers,
cheers,
Daz_C
Like I said in my post, I think they are 16mm. Without checking, which, if I have time later I can do, I can't be 100%. At the moment I'm running 195/50/15 R888's. The tyres on the front sit fairly flush with the arch but I wouldn't say they stick out past the arch.
Vz_ace
Camber is standard?
