dino20vt
Bmw 323i E36 Ecu Temp Sensor Location
dino20vt
Got a mate that's got a problem with rich running and flooding after short journeys, does anyone happen to know it's location?
Many thanks
Autodata says front end of the engine behind the oil filter housing, by the looks of the diagram close to the inlet manifold.
woodsy
If you can get a ohmeter on the switch, you can check if its broke.When temp is hot you should have about
26-310 ohms and when the engine cold have 2000-2500ohms if thats any help.
dino20vt
Excellent, thanks for the info
