backroadpug
Safety Device Cage
backroadpug
hi every one i have a saftey device rear section of cage in my 205 rallye (its a racmsa/fia id.c12)
im wanting to beef it up a bit its only a single diagonal
im thinking of welding in a cross bar and a few other sections and getting the front half
what is the best tubing grade to use?
cheers
http://i800.photobucket.com/albums/yy289/bigbad205/seats.jpg
wracing
CDS
Liquid_106
CDS
To embelish.......
From SD website - have a look as there's some good info for your 'additions' such as this
CDS Carbon Steel
Otherwise known as Cold Drawn Seamless Carbon Steel, this is the material is used to manufacture all of our standard motor sport and 4 x 4 roll cages as it conforms to FIA material specification requirements and offers good elongation and weld-ability, which are key. Compared to T-45 it is a very cost effective material.
Jrod
Modify the cage and it will no longer be FIA approved.
not a concern if its purely UK based MSA regulated competition afaik.
Jrod
I'd have to check my blue book and I can't really be bothered :) I'm sure I was told if modified you can't use it on UK stage rallys when I was looking and adding to an OMP.
Liquid_106
......is it even for competition use......... :)
Yeah screw it then, modify it and make it worth nothing in that case... :)
Same difference!
backroadpug
its just for road use. but i see your point might just look into gettin a whole new cage.
any suggestions on any cages?
