Guest tomchester999
Which Springs For 205 Stdt ?
Guest tomchester999
Hello
I the next thing i need for my stdt project is some front springs for the original suspension.
now i am looking at the eibach ones on ebay but i cant work out which ones i need.
does the stdt have the GTI struts? or does it share with the other models?
thanks
Tom
yeti-dj
hello, yes its got the same struts but im sure the sdtd springs are firmer than the stock gti as the car weights a bit more so you will end up lowering the car a bit but not sure by how much, sure someone can confirm this for you..
hope its a bit of help.
The STDT has GTI style struts (or should have) but normal diesel springs which are massive when uncompressed off the strut.
When I had my STDT I ran it with both 205 GTI which gave about a 25mm drop & later 309 GTI springs on, the 309 GTI springs were better suited imo being very slightly stiffer than the 205 ones & dropped it an extra ~10mm so it sat at a nice height.
Fitting Eibach lowering springs made for a 205 GTI onto your STDT will make it to low imo.
Graham.
