Guest drewz2010
Advise On Engine Change
Guest drewz2010
next weekend im getting a new 1.6gti engine and im just wondering if theres any hints to take out my old 1.6gti engine eg if theres any bits i might get stuck on and should i strip the front of car or does engine come out of top? any advice would be gratefull.
omega
hi your best bet is to do a search as its been covered many times.
but you can take it out from the top or underneth depending on your tools.
Engine comes out the top, no need to strip the front of the car.
Did you try a search before asking? i'm sure there's plenty of topics that'd give you lots of hints and tips.
It's pretty simple really, disconnect & remove battery, drain coolant and oil, disconnect wiring inc starter and alternator, gear linkages, speedo & clutch cable, earths and exhaust downpipe from manifold, remove driveshafts and disconnect lower engine mount, support the engine and undo the top and gearbox mounts, and the engine & gearbox will lift out, you may need to move it around and angle the assembly to get them out, unless you remove the battery tray to gain more space.
mikeygulley
Taking the battery tray out is a good idea.
Rob_the_Sparky
As is getting a load leveler so you can put in/take out with the gearbox pointed downwards as the lump is wider than the hole if you try to lift straight up...
EdCherry
Id drop the engine down slightly to make taking out that battery tray alot easier :lol:
Batfink
hire an engine crane.
Taking it out the bottom is a faff and is only done by stubborn cheapskates like me :lol:
Edited by Batfink
I just tilt the engine/box assembly until it's at a suitable angle, then carefully lift it out.
On occasion though if i'm not in a rush i'll just whip the battery tray out though as said, 4x13mm bolts.
SurGie
I agree to removing the battery tray makes things much easier but just be careful as my trays bolts had seized and the captive nuts broke off. If yours have seized try some of this STUFF.
Simes
+1
