RICH530I
Rear Beam?
RICH530I
Hell I am needing a rear beam for my 1.9 GTI. I have found one which I am told is off a 1.6 GTI. Am I able to swap the disks and calipers onto it off mine? If this beam is not off a 1.6 GTI and just off a normal 205 is there any differance? will it still fit and perform the same?
many thanks
Richard.
jimistdt
If it is a 205 GTi beam then the tube will thicken slightly in the centre, if it's a base model beam the tube will likely be black in colour and you will need to swap the torsion bars and anti roll bars from your existing beam.
You can retain your present brake set-up on the new beam, whichever it is.
Edited by jimistdt
RICH530I
I have now been told its off a 205 van???
jimistdt
Ooh! 21mm Torsion bars, they'll be worth keeping. Not sure on the A.R.B. though. but I'd take it anyway for the bars.
EDIT: Anti Roll Bar could either be 16 or 19mm depending on year
Edited by jimistdt
wont always be 21mm on a van, but there's a chance they could be.
worth noting that if you do get a drum equipped rear beam and want to retain your disc brakes you will need to fit the disc brake stub axles as they are 5mm or so longer.
Edited by welshpug
