cagedbanana
Drive Shaft, Bearing, Wishbone Oall Three?
cagedbanana
went to an event oer the weekend with dragracing
needless to say she took a pounding
on the way home noticed
like a metal chunking sound comming from the front right. almost like metal chafeing. making my steering wheel wobble ALOT at some points
but only experienced when power was being put through the front wheels
also im pretty sure my front left bearing has gone. are hubs easily gotten hold of as both my holding screws for the discs have snapped too
also massive rattle from front left over bumps
take it this is the wishbone?
thanks in advance for any help
cheers
chris
pugpete1108
im experiecing similar problems with mine, it feels like the engine is about to fall out under acceleration?
been told i could be a driveshaft inner cv joint so i am in the middle of stripping it down to find out, whilst putting a new box on too as i found one of the bellhousing bolts have ripped a thread and one was missing.
my bearings a nearly new so it aint that in my case and the wishbones are fine too.
cagedbanana
But its not there all the time, a quick wiggle with the steering can often sort it for a bit
definately need new hubs for a start, but as its running an S16 do i need s16 hubs?
pugpete1108
im just changing my hubs to base model ones so i can fit some larger brakes.
if you have 1.9 gti hubs then stick with them as they are more than fine for most applications, just fit bigger disk and callipers to them
Pugmanian Devil
First thing i would do is jack up the front of the car and start checking everything for excessive movement (play) check drive shaft's, arb drop links, wheel bearings, ball joints, top mounts etc..
