pugpete1108
1.6 Gti Brake Options, Need Bigger Ones.
pugpete1108
i have been doing some reading with regards to what brake options i have for my gti.
currently it has 1.6 hubs and shafts, and i was under the impression i would need to change the whole lot to upgrade the brakes to anything worthwhile.
i now understand that i can fit base model hubs to my 1.6 shafts which will allow me to fit larger brakes from say a 307hdi or similar?
question is what IS a base model 205? an xs? a diesel? or even a base model 309? or what?
hope someone can help clarify this for me as im up the scrappy during the week and want to go hub hunting.
Any Non GTi hub from a 205 is fine, 1.1, 1.4, 1.7D etc, No 309 ones as they all share the 1.9 hub
pugpete1108
cool cheers miles, there is a cj down the scrappy for sure if not there is a van and another 205 that should do.
my 1.6 callipers will fit on base hubs correct? just need different offset disks (just in case i cant get hold of hdi callipers immediatly)
come to think of it, would the mi16 disks and callipers fit the base model hubs? or is it waaay off, i remeber baz saying the hubs were miles out but not sure on the other bits
Edited by pugpete1108
james_pug
I've some base model hubs in the garage you can have for a tenner, one needs a new bearing but I think the ball joint holes are ok, also woodgates should have some 266mm brakes and calipers they were common on 306's I had some from there a while ago and they were only £30 Inc discs.
pugpete1108
cheers james, i'll text ya and we can sort something it out.
what bearing would i order?
Richy_cti
if you get the 1.9 hubs dont the 306 gti-6 calipers and disk just bolt on?
ade 4wd
Yes they do but the OP has 1.6 driveshafts that will not fit 1.9 hubs.
CharlieBoy
If it were me, I'd be tempted to stick with the stock 1.6 setup and go with braided lines (Miles can do these), in addition to some half decent brake fluid (ATE Super Blue is relatively cheap for what it is) and fast road pads (Mintex M1144s).
I have the above and to be honest it gives good feel and doesn't stop too badly either (my discs were relatively new from when I bought the car mind you and my master cylinder was also changed). IIRC the 1.6 setup is quite light too meaning that it has less to stop.
Otherwise you'll need to swap the hubs and go forth with the caliper upgrades as suggested above.
pugpete1108
not too worry.
i got a set of base model hubs from james cheers dude.
and managed to get a set of 380mm disks,callipers,pads and hoses from a 307 hdi for 40 squids today with barely any wear either :ph34r:
oh well, there goes the nice light steering and agility :ph34r:
pugpete1108
i'll trade a bit of handling for actually stopping any day :D believe me my brakes were pooh.
they are heavy though i give you that, i nearly couldn't carry them from one end of the yard to the other. my arms were proper burning
disks on their own weigh near double the originals :ph34r:
CharlieBoy
If they feel crap, it will almost certainly be down to a poor component, be it fluid (an underrated thing that should be changed every two years), sticking calipers, iffy lines or leaking rear slave cylinders. For what the calipers cost new (<£50 each), I'd just repair what's on there, but each to their own. If your master cylinder is on its way out, you'll still not have the full potential from your brakes.
Edited by CharlieBoy
pugpete1108
i can assure you everything was replaced when i refitted the brakes.
new m/c, new pads and fluid, new pipes including flexi's. the callpers were checked and were not leaking or seized.
it went through the mot fine as they are with plenty of grip (or so the mot guy said), i guess after driving other cars for 5 yrs i have got used to much better brakes, so these felt bloody terrible. who knows? anyway its done now
