Turbo7379
Diy Coilovers, Top Mount Problem
Turbo7379
I'm modifying a pair of gp n billys from std springs to coilovers using the compbrake kit here.
http://www.compbrake.co.uk/SUSPENSION/SUSPENSION4.html
I read the 2 posts about a similiar conversion but its not clear how the top end goes together.
http://forum.205gtidrivers.com/index.php?s...lovers&st=0
http://forum.205gtidrivers.com/index.php?s...=77291&st=0
I want to use the original top mounts as they were rebuilt using new bearings & bbm uprated rubber cones ( and I cant afford spherical bearing ones ). The top spring pan supplied looks like the one on the left on the compbrake page but I can't see how it will fit together using any of the original top mount & still retain the bearing & rubber cone. The only thing I could think of was to bore out the centre of the supplied top pan so that it fits over the damper rod but I don't like that idea.
So any of you like Jerseypug who have carried out this conversion please help!
Cheers, Turbo
Turbo7379
I've already got the strut bodys, what I need info on is how to mount the coilovers using std top mounts.
you need a top spring pan that'll fit the standard pug bearing, I'm not sure at the moment where you'd get on of these as the only place I know that do them is having website issues.
http://t1.gstatic.com/images?q=tbn:XXTJIoE...erKit_large.jpg
biggest image I could find :) basically the grey piece of a 106 coilover conversion kit.
try paul@ghostdevelopments.co.uk
B1ack_Mi16
GAZ will get you top spring pan for normal top mount bearings.
jerseypug
cant remember where i got them from as it was over 3 years ago, i tack welded them to the top plates. hope this helps
where's your bearing??
Turbo7379
Just what I was thinking! :D My steering is heavy enough now WITH bearings. :)
I was considering using the standard top spring pans, weld on a ring of 2.5" steel tube to locate the spring & 'trim off' where the std spring sat. Or if I can get access to a lathe I could modify the supplied cone shaped top pan so that it will locate onto the std bearing.
I think my struts don't have a long enough thread to use solid bearing top mounts. I'll know better when I get them stripped out of the car but I'm busy painting the outside of the house atm. :)
Naturally I'm praying for rain so I can get back into the workshop. :D
jerseypug
the bearings were with the spring, just hadnt been fitted.
