danny56712
Mi16 Bad Noise From It
danny56712
Hi lads iv read so much info on this but cant pin point what it is so i said id open a topic..
basically my mi16 sump burst and i stopped fairly fast not immediate but oil pressure guage didn work that night..
anyway now new sump on bla bla and there is a tapping sound from head and only at 3k revs the engine makes a horrible metalic sound real sick sound, only in mid range but still has good oil pressure.
this is an alloy block 1.9 mi16..
any advice would be great help
danny56712
any respionse would be greata as to my knowledge it aint bearings as i have oil pressure
hcmini1989
dry tappets maybe if its coming from the top theres no bearings there . Dry cams maybe take the top off and have a look you might have run a cam dry and its damaged it
Edited by hcmini1989
S@m
I know this noise! Sadly i dont know the cause or the cure, but a previous mi16 i had would make a god awful rattle from the head when cold from about 2700-3000rpm, absolutely no noise above or below this and no noise when up to temperature. I would be very much interested in the cause, however, a friend of mine now has this engine and we are planning a tappet refurb on it in the not to distant future, so i will report if that does any good (or bad).
Also, i believe this engine had a cambelt failure in the past, so i suppose the old 'its not a dodgy tappet, its a bent valve' point of view could come into play, but surely a bent valve wouldnt just make noise at a certain rpm, or go quiet when up to temp?
Anyway, sorry i have been no help at all, but at the very least i have bumped the topic!
Sam
Hope this isn't your problem but...
I smashed the sump on my old 405 Mi16 on a 12 car, realised what I'd done and killed it quick. However afterwards it had a strange tappy rattle in the mid range, and occasionally would go down on power and then recover. never managed to figure out what it was.
Until one day on the M69 it broke a conrod in half and grenaded itself. The lot was scrap, crank, head, block, etc. I think the tap was a little end had picked up, this gradually got hotter and hotter on the M.way until it seized which bent the rod and then the rest was history.
danny56712
right i pulled of the camshaft caps and yes the cam does look scored so persume this is my problem...what you think
S@m
Tom, i really hope this isnt the problem on my friends engine because he got it from me (although i was completely honest about the rattle and he heard it many times when we were trying to diagnose it). Although, did yours only make it when cold in the midrange, and did it disappear completely when warm or when out of the mid-ish rev band?
Thanks in advance,
Sam
TBH I don't remember the details now, it was about 8 years ago!
S@m
No worries mate, thanks anyway. I hoping its just an incredibly sticky lifter, but we shall see!
