zx-vts
Hybrid Box Issues
zx-vts
hi guys, I need some advice regarding be1 and be3 gearbox. I had planned to use the gear set (1st-5th) from a 1.9 gti be3 box with a xsara vts crown wheel and pinion and case it turns out due to a dodgy ebayer ive ended up with a be1 box. basically i need to know if the gear sets (1st-5th) from a be1 and a be3 are interchangable and will I have any issues with reverse? Im unsure of the difference between the 2 box's other than where reverse is on the gear stick. cheers in advance.
Yes you will, Only a couple of gears are the same plus the VTS output shaft is longer
luggy
Be1 and Be3 are interchangeable if your putting BE1 gearset into a BE3 you need to flip 1st and 2nd gear selector (because it has the reverse gear attached) and flip the reverse idler gear.
Did this for a forum member who had motronic management on an s16 conversion but had a Be1 box and didnt have the CPS hole in the gearbox and transferred it into a BE3 casing for him. :)
Doesn't always work as there are slight differance's, even the gears are cut differently thruout the years
zx-vts
Thanks guys, i think I'm back on the hunt for a be3 from a 1.9, Im not even sure which car the be1 came from.
do all be1 box's have reverse next to 1st?
Edited by zx-vts
alync406
Yes reverse is beside 1st on all BE1's.
pugpete1108
do you have a 1.9 be1 unit for sale then?
pete
zx-vts
pete
possibly mate, Make me an offer.
pugpete1108
just realised you are a million miles away from me, so would be far to uneconomical to have it shipped.
cheers though B)
zx-vts
cheers though B)
no probs mate.
Thanks again for the info guys.
