hcmini1989
Wing Removal Help
hcmini1989
Right im taking my front wing off ive taken all the bolts out and its stuck on.Now after abit of searching it seems like it stuck on with sealer now were do i cut is it inbetween the inner wing and outer .So i would need to stick a knife up iniside the wheel arch or is it along the top of the wing where it bolts on under the bonnet
matt.f
From inside the wheel arch you can see where the wing touches part of the inner wing panel.If you are fitting a new wing try heating the sealer up from outside(on the painted side) it makes it easier
backroadpug
you have got the bolt thats inside the car off thats the one that caught me out first time i removed a wing.
the sealer does take a good hold also.
hcmini1989
:D i need a wing now i ended up getting most of it but couldnt get the bit where it meets the inner wing so just pulled it .Its off now anyways cheers for the help
