Dandu
Hi mates,
I appreciate your help, but the spare part is already on the way. <_< Just as I mentioned ... it was a matter of time. Fortunately a short time. ;) Much thanks anyway.
Bye Dandu
Edited by Dandu
Dandu
@Tom Fenton: You were absolutely right. I'm very grateful, that you draw my attention back to the hoses. Today I replaced the leaking hose and ... the boost pressure came back. Yeah. :unsure:
At the proper time I'll give the other ECU a try again. Just to come back to the original question: How do I cut the overboost in order to maintain a constant boost pressure at 14 psi (via reprogramming the software of an ECU)? Actually I've been very close to the answer. I hope, I can assure myself of the correct solution a little longer next time. ;)
Much thanks for all your help! Cheers Dandu
Glad you have sorted it. Many people always suspect the management to be at fault with things like this, but 99 times out of 100 it is some mechanical problem that has nothing to do with the management.
