credowan
Citreon C3
credowan
Hi, im sorry this isn`t concerning a peugeot but would like some advice so thanks in advance,
My girlfriends C3(just get that in ) has a whine (that isnt her) that seems to be coming from the camblt area but as with these small cars its hard to tell completely as tight engine space could poss be aux belt or AC compressor but seems higher my qusetion is would the belt whine or tensioner if on way out, Has anyone had probs like this
Thanks in advance
Gary
Edited by credowan
hcmini1989
Hi just wondering i
give us a clue then
learn to Spell Citroen first :lol:
credowan
Sorry about both above comments added topic before finishing and as for spelling was rushing it should have been s*itroen sorry again Citroen
Gary
Edited by credowan
this should be in TU section BTW, unless its a diesel one?
The Timing belt tensioners on these are sprung and can be tricky to get the tension right so it may be the timing belt, there's also an idler pulley and a water pump that could cause the nosie.
credowan
No its not the diesel version so guess it needs to be in the TU section, didnt want to place it in the TU section just incase, if a mod could move the topic it would be appreciated
Thanks for the advice and heads up on the above
Edited by credowan
hcmini1989
Just wizz the aux belt of see if still does it the noise when running.If it does stick a belt kit on it these are`nt that bad to work on
