blackpug
405 1.9td
blackpug
Hi, I've just bought a 405 1.9TD for the engine bottom end and gearbox, and was wondering are there any other parts worth keeping? Hubs/shafts/brakes etc?
Ta,
Ad.
Daviewonder
If it has one touch electric window switches keep them :lol:
blackpug
They the same as 306 ones? Haven't had time to look
monkee87
Can you use the 405 switches in a 205 for a one touch window?!! If you can i want one! :lol:
KRISKARRERA
Different connectors though if I remember correctly so some rewiring would be needed.
hubs and brakes don't go straight on, though Colin satchel does use them in his bump steer corrected geometry.
brakes only fit 405/6 hubs.
driveshafts obviously a bit too long :lol:
what year + colour and is it a saloon or an estate?
blackpug
It's a red GRDT estate on a K plate, after any bits? Will be going scrapper by end of next week.
It's got one one touch switch but it doesn't feel healthy (can't test most of the engine loom has been cut out)
Are the steering racks the same? (apart from drumsticks) they look similar but haven't got a 205 one off to compare it with.
Edited by blackpug
KRISKARRERA
They're not quite as tough as the regular switches. Had one die on an old 405 and the stealer wanted £36 for a new one. So I tried to fit a normal one but connector was different.
