iamjackiechan
205 Rallye Engine Mount Pics Please
iamjackiechan
Hi
as title says could someone please post up some pics of 205 Rallye engine mounts please
will
iamjackiechan
sorry i meant on the car.
but the reason i asked is that ive just fitted the 1300 106 rallye engine and it sits on the wonk, i did a search on the forumm and found that i need a 93 or earlier top mount as it is longer. it was hard enough finding a standard tu top mount let alone a 93 or ealier one.
is what ive said about the mount correct and if so which models of 205 can i get one off
cheers will
GeorgeXS
cheers will
I almostly definatley have what you want, i'll take a picture tonight to confirm.
iamjackiechan
that would be great if you do, could you measure the overall length so i could compare it to the one i have.
thanks
custard-rallye
I could get pics at 6 and send them in a txt pm your number if you want
iamjackiechan
thanks thats a very kind offer, if you could send me a pic of the top mount and the lower mount onto the subframe that would be great. il pm you my number.
here is a pic of how the engine is sitting at the moment
it looks like the cam pulley is meant to be inline with the mounting point on the car, so a longer mount should work.
will
burr_2000
i have fitted 206 and 106 engines using my original 1993 205 rallye engine mount and a older xs 1990 engine mount. keep the 205 part that the mount attachs to on engine and switch it to 106 engine but cant see that being problem.
seems strange there would be different lengths on the 1360 TU 205s.
do you have a link to the old thread about lengths as its interesting.
If you get really stuck Will, there's an F-reg 205 XS in my local scrappy that still has the engine mount on :)
backroadpug
all the tu3 engine mounts are the same pre 93 even off a base model 1ltr so dont think it could be that.
very strange one
iamjackiechan
custard rallye just sent me a pic of his top mount and it definatly looks longer than mine.
im confused
looks like you have used the 106 arm?
Edited by welshpug
iamjackiechan
the mount is off a 205 xs
burr_2000
i cant understand why 1993 makes a difference. very strange one, but you do say its the same one from your 205 xs :D
iamjackiechan
yup, i took it off an xs at the scrapyard.
so what are peoples suggestions that i should try, if any.
cheers will
GeorgeXS
The mount in my XS looks to about the same length as the one in your picture, however the mount on my XE is way longer, will get a pic for you tomorrow.
burr_2000
Can you remember what age of xs, remember the early models had I think XY engines and not TU.
iamjackiechan
I can't remember what year xs it was off, I've never heard of an xy so could that have a different mount
BERTMAN
is the part of the mount that bolts onto the block the right one, not the arm itself... maybe 106 ones were different?
if it is a 205 arm you need, that is part number 1839 20, costs £57 new.
it is used on the 309 405 and 306, though only on the TU1 and TU3 engines, so should be pretty easy to find.
the bracket on the block for the iron blocks is the same, the alloy block one incorporates the water pump housing, 120445, is the same for post 91 cars, but not earlier cars which was 120434.
no idea what the difference is, but can't be much as the arm is the same pre and post 91.
Edited by welshpug
GeorgeXS
Right I got around to taking a piccy of the mounts.
Difference in size is massive, The XE (white) which is a TU9 engine?, has a massive mount.
My XS has a fairly small one.
The inner wing seems to contribute most of the difference though the XS one sticks out much further. Any ideas why?
Engines are the same distance away from strut tops, why are the mountings so different?
second one seems much closer to the inner wing.
swordfish210
I'd say the shell is different. Look at the design of the metal-work surrounding the engine mount
