blessed6383
Gear Rod Lengths?
blessed6383
does anyone know the lenghts of the 2 gear rods on a gti?
dee205
Miles will likely be able to tell you as he does uprated sets. Failing that I'll be mmostly stuck under mine the rest of the day so will measure. Think all 5 speed 205 models should be the same afaik
jord294
123mm centre to centre, short rod
285mm centre to centre, longer rod
Just adjust them on the car, The std lengths are normally wrong as with all things 205 the shells are well out
blessed6383
cheers guys thanks for the info
