rory1
Hi I am doing a 2.0 turbo conversion from a 406 to my 205, I know I need an adapter to get the oil pressure gauge working. The question is willl the one for a 306 GTi 6 be the same as the one for the 406 engine?
Paul
whizzer71
Paul
Oil pressure guage or light, the 6' doesnt have a guage so youll need a sender from a Citroen ZX16v or you can use an old oil switch (the one that does the light) cut the top off it and drill and tap to accept the sender from your 1.9 engine.
Either method will do And I have used both in the past, alternativley there is a pre made adaptor available from Miles on here, doesnt cost much either.
Edited by whizzer71
rory1
I used this- click
That's the one I was looking at, just wanted to check it would do before I bought it
Thanks for the help
