stuart1298
1.6 Gti And 1.9 Gti Differences
stuart1298
i am looking at a set up of front shocks, with springs, i have a j plate 1.6gti, and this set up has came off a 1.9 gti and i going to have any trouble fitting this, also with brake callipers is there any difference as i'm looking at bigger brakes will i have trouble with fitting them, hubs yokes callipers etc, dont wanna buy a bigger set up then find i need to replace a s*it load more, if that happens i would rather get down a breakers yard n fet the whole front set up
Cheers Stu
Daviewonder
Shocks and springs will fit straight on, I'm not sure about the brakes though ;)
hothatch
What he said !
And you can fit 1900 calipers to your 1600 hub carriers but will have to use the 1600 discs because of the offset. Any bigger like gti6 calipers you need 1900 hub carriers.
Ben
stuart1298
so to fit bigger brakes i would need the 1.9 hub carriers, hubs and bearings?
Stu
and 1.9 driveshafts.
OR base model hubs and retain the 1.6 shafts
stuart1298
Sounds about right, jus put 2 brand new drive shafts in, in the last couple of months, so if i got hubs and hub carriers off a smaller enginged car i can put bigger brakes on? sounds strange to me, but then again, it is french...
Stu
yes, its because the offset of base model hubs are the same as a 1.9.
afaik 1.6 had a 10mm taller hub to fit the 247mm brakes under the 14" wheels ;)
stuart1298
so i need the hubs, carriers and bearings then?
then i should be sorted?
yeah, they'd normally come as one unit though ;)
stuart1298
from what i find out using the pagid system, the brake disks are the same on a 1.9 and a 1.6, so in theory the offset should be the same?
stuart1298
this is all a pain, ah well, i'll get hunting round the breakers in the next few weeks then, cheers mate
alync406
The discs are the same size 247mm but the offset is different.
They must know something Peugeot don't then because there are different discs, calipers & pad fitted to the 1.6 & 1.9 GTI, nothing can be swapped between the two as standard.
Graham.
Adrian247
Graham.
I thought you could fit the 1.9 calipers to the 1.6 whilst retaining the 1.6 discs, without problems?
You can & they do fit straight on with no problem.
I worded my previous reply wrongly, the calipers & pads are the only parts you can swap between the two but not seperately.
Graham.
Adrian247
Graham.
Thanks for clarifying that, had me worried for a min as I have just bought some 1.9 calipers to go on my 1.6 road rally car as I am fed up with the crap bleed nipples on the bendix calipers.
