Jer309GTi
Non Working Speedo
Jer309GTi
The speedo on my XS doesnt work, and I have been checking it to see whats wrong. I'm sure the speedo drive is at fault as the cable is nice and free and the needle moves when you spin the gearbox end of the cable with your fingers.
Is changing the drive a gearbox-out job? Or do you just undo the bolt and it all pulls out? Wasn't sure so didnt want to go ahead and try and it all falls to bits!
Also, is it worth getting a second hand one or get one from Pug? Not sure if this is a common problem with MA boxes or not.
Cheers :lol:
chrisj21
If it's the same as a BE gearbox then there is just one bolt on top and it pulls out as one unit.
You may get one from a scrappy as Peugeot would be expensive i'd have thought. Or try ebay.
Daviewonder
I'm not sure if they're colour coded depending on the amount of teeth? Might be something to watch out for if getting one from the scrappy if you want your speedo to read correctly. I'm sure someone can confirm this :lol:
swordfish210
MA gearboxs do have different speedo drives. The one from my XS box was different to the one in my AX GTI box, same fitting but different gear diameters. They all fit and are easy to remove with the box in place.
they aren't actually expensive from Peugeot if you need a normal non-electric one.
there is a choice of 17 or 18 toothed driven cogs, the drive cog is always 19t in a 205.
total parts are about £14 + vat.
264150 CONTROL SUPPORT 3.92 GBP
264916 CONTROL PINION 6.05 GBP (17 teeth)
264915 CONTROL PINION 6.16 GBP (18 teeth)
264404 TACHOMETER SEAL 4.11 GBP
264512 RING-SEAL 0.40 GBP
one thing I'd be concerned about with an MA box though, is that if the speedo cog has failed, how long till the diff bearings fail? as its play in these that causes the plastic cogs to break/wear out...
ilovemypug
cheaper than in portugal... nearly 40 € for the cable..
I did not list the cable, but when I got one for DrSarty several weeks ago, it was just £23, the shorter lhd cable is £28.
Jer309GTi
Thats what I was worried about. Fingers crosed the diff is ok!
Thanks for all the replies ;) I'll see if Pug can order me one in
guy at peugeot temple meads I think is Luke, he's a gti6 owner ;)
Jer309GTi
Is that the younger bloke, whos always there on a Saturday morning?
I believe so, drives a Moonstone on OZ wheels.
Jer309GTi
Oh right, I'll have to have a chat with him when I'm in there then ;)
