Guest markrs s2
Brake Disc Help Needed
Guest markrs s2
Hi there i have a 205 gti 1.6 shell with 1.9 engine , 1.6 gearbox etc ordered some new discs from bembo presuming they would of been 1.6 ones but when i took the old ones off the depth is much shallower than the new one, the new one doesnt fit flush on the hub if this makes sense! So does this meen they are 1.9 hubs therefore needing 1.9 discs??? Help
Dont know how to put pics up sorry!
Cheers mark
they could be base model or 1.9 hubs, either will require a 1.9 discs if you are after a vented item, the 1.6 is about 10mm taller in offset from the face of the bell to the disc.
Guest markrs s2
Cheers they seem about 10mm different the disc is hitting the caliper bracket and not butting wright up to the hub. Hope brembo will swap them.
Cheers Mark
