Guest Houghy
A Quick Question For Someone.
Guest Houghy
just a quick one needed, im about to order a 205 headlight from a breaker, i was just wondering if all 205 headlights are the same ie, the fixings (beam adjusters) are the same on a base model to the gti model?
Dave
jimistdt
I'd say so yes, I have had one before that had a much deeper reflective casing, but otherwise was identical and fitted fine.
dumbiron
and i am going to say no, got a selection of head lights in the garage with different adjusters on them.
dave_gti
The headlights are so easy to remove, so maybe take yours off and take it with you to compare?
All 205 models use the same headlights, there are different makes available as pattern parts, most (all?) of them are rubbish apart from the original Valeo ones but they all fit in the same way.
Don;t forget new OE ones are only a shade over £20.00
