Apart from an exhaust manifold I have the majority of the bits now to build an engine that should thoroughly test the limit of that clutch....
Slo
Not had any clutch problems with mine whatsoever "yet" and mine was a £25 delivered reconditioned cheapy citroen bx clutch kit off ebay
wicked
I run approx 325nm on an OMP clutch and plate with no problem. (215mm)
Edited by wicked
205turbo
How much boost are you running?
205turbo
Mines running 345nm but will run more later on when we get it upto holding 20psi
Alastairh
I had a helix in my old T16. Never once gave me issue no matter the amount of abuse given. Also was surprisingly smooth to operate.
Al
BULLFROG
@Tom Fenton & 205turbo
Do you guys have in the meanwhile experience with the Spec clutch ? - I'm also thinking about to purchase this clutch due to same problems as you had.
BULLFROG
nobody experience with Spec clutches ? ... :unsure:
I've got one on the shelf but not actually used it. The customer service when I bought it was good, they are in the USA.
