Rich_p
Remoing Windows
Rich_p
I've had a search and most posts advise on how to fix broken windows.
I am trying to remove the windpws and all the electrics so I can fit my poly windows.
I have undone all the nuts as the Haynes manual suggest pulled away the bottom support bit but as hard as I try I cannot get anything to budge.
What am I doing wrong?
j_turnell
They are well wedged in, just have to push the studs through, some times a gentle tap with a hammer and punch does the job but usually pulling the motor from behind and pushing the studs from the front pushes it out. Once out slide it through the main hole where the central locking motor is.
