dodsworth_gti
Hub Ball Joint Pinch Bolts
dodsworth_gti
hey,i need to find some new ones .................................... tomorrow!!!!!!!!!!!!!!!!!!!
got my mot and it should pass apart from the dodgy bolts that are in now,any one know where i can get some in a hurry??
many thanks
ben
Peugeot may have them on the shelf if you're lucky?
dodsworth_gti
id be very lucky,my peugeot dealer doesnt want to know about 205's at all
Rippthrough
Screwfix, M10x55mm will do you.
Edited by Rippthrough
dodsworth_gti
yeah thats exactly what i was thinking,and if i go fast pack i can get them in high tensile with locknuts!
Although generic bolts will be threaded where the ball-joint sits, unless you get a very long one!
Edited by Baz
Paul_13
Local scrap yard?
They're the same as 306 pinch bolts.
Don't buy sh!tty halfords bolts, mate used them and they swiftly removed themselves. Gearbox oil all over road and wheel sat waaaay out the arch :ph34r:
Edited by Paul_13
Rippthrough
Nah, set screw would, bolts won't be.
If you're passing by here any time I've got boxes of 'em.
dodsworth_gti
nah its fine paul,running on s*it bolts at moment
just sent my man at fast pack a pic of some pinch bolts,and he is going to sort me with some 12.9 tensile bolts that pretty much replicate the standard ones with same hex spanner head for a couple of quid
he always comes up trumps for me :ph34r::D
its not what you know,its who you know!!!!!!
Good luck. :ph34r:
shalmaneser
I'd give your pug dealer a ring, it's worth a try to get the proper ones, it's the same part for 306/309/205, maybe even the 106 so they should have them. You'll ruin your hubs pretty quickly if you use s*it ones.
