A2TheA
Best Paint For Centre Caps?
A2TheA
Hi all, what is the best paint to do the centre caps?
As I said In the title mine just flakes off. I have even keyed the face to try and get a good bond for the paint.
Just wondered what paint you used or are you like me and keep having to repaint them every month or so?
Aaron
NeilGTi85
more laquar?
Mine have been fine, used halfords paint & laquar
zebedy101
Have you looked at buying some new ones? I think there only about £20 from the stealers.
A2TheA
more laquar?
I'll put some more on. See if it helps.
They are in good condition it's the paint colour/customisation that's bot working. The new ones are silver to match the silver original coloured wheels. Mines are White, and silver caps just won't match.
Cheers for replys
Edited by A2TheA
scotty
Try etching primer on them 1st then paint might help.
zebedy101
Ahh sorry I didn't realise yours where white.
richsmells
When I sprayed mine, I took more time to carefully sand the raised peugeot lion so that all the old paint was removed. Then I used a couple of coats of Upol primer, followed by silver, then laquer on the face.
A2TheA
Will purchase some etching primer and have a go with that.
Seems a few people have slightly different approaches with good results so I'll have a go with one and try the others if it fails :ph34r:
Many thanks guys.
Aaron
joe1joe
well i find that using a scouring pad (even the ones used in the kitchen for be cheapo) to scratch them slightly when wet, then followed by sandpaper to do the bit you can get to and then plastic primer then primer then colour, if the paint is knacerd on them already prob best to nitromore them to remove the paint first!
gixxerash
yeah defo use plastic primer, make sure you get loads a laquer on the edges of the caps so when you put them back in the wheels they don't flake off.
A2TheA
sweet. ill get on this today i think as the car goes back together soon :ph34r:
