AJA_GTi
Tools You Would Not Leave Home Without?
AJA_GTi
What tools do you feel are essential to carry around with you in your pug given the limited space. I had a traumer today and needed to clean the airflow sensor so i'll start.
  1. small selection of ratchet spanners
  2. can of carb cleaner
  3. phillips and flathead screwdriver
Edited by AJA_GTi
gixxerash
AA membership card :)
Edited by gixxerash
hcmini1989
  AJA_GTi said:
What tools do you feel are essentiol to carry around with you given the limited space. I had a traumer today and needed to clean the airflow sensor so i'll start.
  2. can or carb cleaner
  3. phillips and flathead screwedriver
currently im running around with a slide hammer/hub puller ,crack bar ,spanner set 6mm-36mm .socket set.screwdriver sets,stubby ratchet spanners.trolley jack,axle stands,brake bleeder,brake spanner set,mole grips,pliers,3/8 ratchet,wobbly extensions ,6mm-19mm sockets , 36mm hub socket , ball joint splitter ,3 pry bars .oh and a range of hammers
i think thats everything its my cars maiden voyage and the bottom pulley fell to bits :)
Edited by hcmini1989
AJA_GTi
must have done that at the same time lol
Got and got. lol
I sorted mine before I bought the car :D
gixxerash
  Simes said:
AA Membership card.
Rich_p
cables ties, they fix most things :)
AndyJ
  Simes said:
AA Membership card.
Currently I have behind my seat:
1: roll of spanners
2: wheel nut key!!!
3: steel bar (to bang the starter motor with when it sticks)
4: gas soldering iron & solder
AJA_GTi
i think thats everything its my cars maiden voyage and the bottom pulley fell to bits :D
Yikes - your car must weigh the same as a hummer :)
gixxerash
prob more than the AA has to be fair think i might just take your username card round with me instead lol.
hcmini1989
You can never be to prepared just a shame i dont carry a spair pulley with me . Have to say though there isnt alot tiy wraps wont do
HERMAN
selection of hammers
GLPoomobile
Just as well you've got over 300lb/ft of torque to haul that lot along! :)
jonnyturbo
always take my trusty halfords tool kit with me
hcmini1989
Yeah a medium size ball pain ,a large ball pain, a lump hammer, and a sledge hammer only added the sledge hammer as i needed to get some stub axles out the other day and they were a pain.
saves walking backward and forward from the shed
Just as well you've got over 300lb/ft of torque to haul that lot along! tongue.gif - yeah paper work to back it up aswell :P - may not be right though?
gixxerash
gaffer tape use to hold my mk2 escort together lol.
Edited by gixxerash
gixxerash
theres always 1 thing you forget when you go out the door lol.
dcc
essential kit :
cable ties
jump leads
wheel brace
jack
air pump
thick jumper/coat
umbrella
gixxerash
change for a taxi home :P
EdCherry
Knife, Keys, Kock.
hexhamstu
RAC Membership card.
hothatch
  Rich_p said:
cables ties, they fix most things :P
And a pair of sidecutters !!!
I nver used to carry much round with me, just sidecutters and a powerbar for my wheels.
I think every 205 has a set of screwdrivers in it though! I'm dirty all day in work so the last thing I wana do is get dirty in clean clothes! Hence the RAC or AA membership lol!!!
SurGie
As well as,
1) Drinking water,
2) Road side triangle. (~I once broke down near Loughborough, i put the triangle out and the next thing that happened was two big police vans pull over
from the other side of the bypass, they see the triangle and off they went, saved me a bit of hassle~)
3) Wind up torch,
4) Food,
5) Cable ties have help me loads before now.
6) Pliers
7) Gloves
8) Mobile..
timb1046
nomaly in any car i own and drive reguarly, i keep:
socket set,
adjustable spanner,
scrwdrivers; 2 flat head, 2 philips,
jump leads
gaffa tape
insulation tape
wheel brace and locking wheel nut key
and if i've got my work tools with me then theres even more!
