jason7579
Ht Lead Holder Won't Fit?
jason7579
The pipe pictured (split one going to oil filler cap I think) is getting in the way and I can't get the HT LEad holder to fit in front or behind it?
Any ideas? Have I got something on wrong or is it just the wrong hose on that pipe?
Errrr.... that shouldn't be there. That should be a bleed point for the thermostat.
If that goes to the oil filler cap, that pipe should be connected to the top of the throttle body.
jason7579
Thanks, think I need a good look at my leads and wires then!!! No wonder the hose doesn't fit.
Should that pipe have a screw in it then or should it be open?
Thanks for the help.
Edited by jason7579
Should have a plastic thumbscrew in there, but they're almost always snapped off leaving the bleed point sealed. If there was nothing in there, it would gush coolant out (and into the oil filler cap, which would be FAR from ideal)
jason7579
Thanks, think I'll go sort it now.
mine has a brass bleed screw there with a copper washer, allen key head.
Daviewonder
Both of mine have this too :lol:
jason7579
Did some midnight mechanics and found out mine has the brass screw too. No idea why the hose went to it?
Thanks for the help
