humanz
Removing The Rolled Door Pins From The Door Check Straps
humanz
Done a search, and none of the posts truly explained how it is done. I need to replace one of my door check straps, but I'm not sure how I should go about removing the rolled pin that keeps the strap attached to the body. Should I just squeeze the pin and pull it out? Hammer it out? Some other method?
Will the pins likely get damaged in the process? Did peugeot change the pins between phases or they all identical?
Remember, I'm talking specifically about the pins for the check straps, not the door hinges. I read all about the problems for the door hinge pins.
EdCherry
Use a drift and hammer them out.
Cameron
Use a pin punch.. and if you don't have a set get one, they're so handy! Brumster's idea about hitting them upwards could make refitting easier, and also try not to knock them out completely, just get them out as much as you need to then you won't fire them across your garage when you try to put them back in. :lol:
lemmingzappa
I ended up hammering mine out downwards using a screwdriver and a hammer. Worked fine :lol:
