davev
Gti6 Wiring
davev
alright all. im currently helping a mate with a gti6 conversion on his 205, and could do with a bit of help on a few matters.
the main problem at the min is on the wiring. after alot of head scratching and searching i have found that we are using a phase 1 block and loom which should relate to this pic. though it dont have an oil temp sendor(wires been added in on the converted loom)
http://img.photobucket.com/albums/v232/ing...r-diagram-3.jpg.
though the loom seems to have about 5/6 connectors that dont have anything to put them on. ive found what a few are for from searching, but theres a couple that i cant find any info on. mainly a 2 pin black connector by the throttle body.(ive figured out the brown(a/c) and white(revrse light) ones)
and a green 2 pin connector sitting by the oil pressure sendor(i thought it was gonna be oil pressure switch until i found that its a phase 1 block, but now im stumped as the knock sensor and oil level gauge are the only other two green connectors and are both pluged in)
to help with possible solutions and maybe help others later on, i have found a pic that pugtorque posted a while ago and ive put all the lables on the connectors(though his loom seems to be missing a few, but ive listed them in the bottom corner)
(hopeing the pic is clear otherwise ill redo it with larger writing later)
http://i116.photobucket.com/albums/o27/dav...6loommarked.jpg
thanks. dave.
p.s. the other 2 connectors lose were the pas pipe one(blue 2 pin and not used) and a black 2 pin that i believe goes into the stepper motor(ours was missing)
p.p.s im not a regular on posting pics so im sorry if they come out big or have any problems.
edit:bottom pic is way to small ill try to get it bigger.
Edited by davev
davev
i feel like an idiot. as ive found what the green connector is for. i lied earlier and its the oil level sendor. i just had the other end well and truely tucked out the way and thought it was connected when looking over.
so its just the black connector. although i dont think its needed as ive read about there being a connector that is not used.
